Stratix IVGX (EP4SGX70HF35C3) PLL+SERDES issue
Eventhough ADC interface use the DCLK , from the TIEVM design looks LVDS which is connect to ADC is using LVDS clock .I am looking into the RTL viwer , Here is the screen shot for your reference . If you would like to use the right / left pll kindly request you select the right bank pll for coressponding LVDS channel.
Also let me know how i can help you further to sort it out ?
Thank you ,
regards,
Sree
- RBach67 years ago
Hi Sree,
not sure what are you looking at. TSW1400EVM calls the clock DCLK on the schematic which is mapped to clk_lvds_rx0_p in the code and it is on the pins AA7 and AA6 which is connected pll_R2. When I create the megafunction, it shows it has to be implemented in Left/Right PLL and it is fine without the altlvds_rx component. It maps to pll_R2. As soon as I add the serdes component, it complains about pll which drives non dpa-mode serdes is driven by an uncompensated input. I am not sure how to fix this error and what is causing it
Ramakrishna
