14 years agoStratix IV GX dev kit
Hi all,
I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of this boards by using the clock input/output? Any other thoughts on what to use to get this 16 transmitters working? Thanks in advance!14 Replies
and though its still early and ES, have you looked at the SV SI kit?
can you give more information about what you're trying to do? not only are there physical restrictions on how many transceivers are accessible through HSMC or SMA, but there are clocking resources and other place and route issues to consider. these sorts of questions can only be answered by doing a feasibility study in the Quartus
Thanks for your quick answer Dave!
Regarding Stratix IV GX dev kit, problem is that the reference manual quotes 12 channels with 8.5 Gbps + 6 with 3.5 Gpbs (I don't know why). That is in page 2-5. I would like all of them to have the same performance. I am also not sure about the PCI: can I just use that physical interface but custom configure the transceivers? The DE4 is a little bit of the same: it quotes only 12 transceivers available. http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=138&no=501&partno=2 So I still don't know what to do. Am I reading any of this availability in a wrong way? - Altera_Forum
--- Quote Start --- I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of this boards by using the clock input/output? Any other thoughts on what to use to get this 16 transmitters working? --- Quote End --- You mean the Stratix IV SI kit? You can also use the Stratix IV GX development kit. It has two HSMC connectors with 8 + 6 transceivers, and then the PCIe edge connector with another 8 transceivers. Samtec sells cables for HSMC-to-SMA breakout and for PCIe-to-SMA breakout. The DE4 kit could also be used. Cheers, Dave
