14 years ago
Stratix IV GX dev kit
Hi all,
I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of this boards by using the clock input/output?
Any other thoughts on what to use to get this 16 transmitters working?
Thanks in advance!
    i didn't see that the SV SI kit 21 channels of backplane transceivers weren't sent to the same connector
    have you looked at the non-transceiver output delay chains? they are adjustable in 50ps increments
    Pankake,
    the output delay adjustment cannot be used for this, I have checked that. Thanks for the suggestion anyway.
    Dave,
    it's all different sequences, so I do need the different channels. I have checked the Samtec interfaces and it does not seem obvious to get that up and running quickly. This should be a quick-development initial prototype, so I think I will buy one Stratix IV GX with the 8 transceivers to SMA and figure out if that can do what I want. After that I will bug you again with the synchronization :)
    Thanks a lot for your help, both of you!
    --- Quote Start ---
    --- Quote End ---
    Ok.
    --- Quote Start ---
    --- Quote End ---
    The Samtec interfaces are just breakout cables. You just plug them in :)
    Cheers,
    Dave
    "The Samtec interfaces are just breakout cables. You just plug them in "
    You are right Dave :), I am being lazy here. It just does not seem very straightforward to buy them. I have asked them for a quote already.
    The information on the dev boards is sometimes confusing, so here it goes in case it helps someone and someone can help me. The Stratix IV SI kit with 8 SMA channels actually has the 8 channels routed through different paths, to provide insight on the effect of different transmision paths on the SI. So the channels are not matched. That is not very difficult to fix but I think it is annoying.
    Here is different option based on the Stratix IV TR4 dev board
    http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=138&no=683&partno=4
    in the reference manual there are 8 channels routed to HSMC-A and 8 routed to HSMC-E. That, plus the adapter XTC-HSMC (or a similar, custom one that provides the right amount of channels) can do it. But once again something confusing: in the webpage they list only 8 transceivers available.
    If any of you has any experience with this board I would appreciate any comments. I will directly ask Terasic about this. Otherwise I hope this is the right choice.
    Again thank you all for your help!
    Miguel
