14 years agoStratix IV GX dev kit
Hi all, I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of thi...
14 years agoPankake,
the output delay adjustment cannot be used for this, I have checked that. Thanks for the suggestion anyway. Dave, it's all different sequences, so I do need the different channels. I have checked the Samtec interfaces and it does not seem obvious to get that up and running quickly. This should be a quick-development initial prototype, so I think I will buy one Stratix IV GX with the 8 transceivers to SMA and figure out if that can do what I want. After that I will bug you again with the synchronization :) Thanks a lot for your help, both of you!
