14 years agoStratix IV GX dev kit
Hi all, I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of thi...
14 years ago --- Quote Start --- Any thoughts about synchronization of 2 Stratix IV GX with the 8 SMA transceivers? --- Quote End --- I use the clkout_sma on one board to send its reference clock to a second board. The transmitters on one board route to receivers on the second board. The receivers start off in lock-to-reference mode, and then switch over to lock-to-data mode to capture the data from the transmitters. You need to ensure that the transmitter data stream has enough toggles so that the lock-to-data logic at the receivers work. You can use a PRBS sequence at the transmitter to modulate data, and then a PRBS sequence at the receiver to demodulate. When you power-up, you first have to synchronize the PRBS generators between boards, and then enable transmitter data. Cheers, Dave
