14 years agoStratix IV GX dev kit
Hi all, I am looking at buying the Stratix IV dev kit. It comes with 8 transceivers routed to SMA connectors, but I need 16. Is it feasible to (with a decent performance) synchronize two of thi...
14 years ago"can you give more information about what you're trying to do?"
what I want to do is to have 16 high speed transmitters that I am going to use just as high speed serializers with around 5 Gbps max rate (protocol in Basic mode, all the blocks bypassed, only a high speed serializer per channel going on). The only requirement is that I need all of them to be synchronized (and that I might need long chains of 1's or 0's, so it will be DC coupled, but that should not have anything to do with this). "and though its still early and ES, have you looked at the SV SI kit? " yes, but again it does not have 16 channels routed through the same interface, which would be preferable. However, based on what you are saying, I might have to deal with that anyway. Ok, so regarding the stratix IV (or even de DE4), suggestion would be to use the HSMC with maybe the samtec arrangement to sma, and the PCI to sma too. All that would allow to have all channels with the same performance and synchronized? What I don't like as I said is the complexity of having two or three different adapter boards - connector interfaces - etc, but it looks like the only way to get 16 channels to work. Any thoughts about synchronization of 2 Stratix IV GX with the 8 SMA transceivers? Thanks a lot!
