10 years ago
Stratix iv GT General Purpose I/O's
I'm working on two projects, one with the DE0-Nano and Stratix iv GT boards. My project is to make a duobinary signal with the two boards. I was able to do so with the DE-Nano fairly easily, but I'm having trouble doing it with the Stratix iv board. I was told not to use the transceivers on the board, but instead use the general purpose user I/O header field because they act similar to the GPIO pins in the Nano. However, I see them all labeled only as J25 and not individually so I'm not able to make the correct pin assignments in the pin assignment editor. I need to activate two of those pins so I can connect them to a circuit I made and test the signal. Help is appreciated
    I hate to say this, but without documentation or a previous Quartus project or an assignments file, you really don't have much to work on. I suppose that you could dissect the binary file to determine which I/O is set in a certain way, but:
    What is the Stratix board that you are using? Schematics should be available, unless this is a custom board.
    I do not have a paperback of the board schematic. The last student that last worked on it lost it. So my only sources so far have been from the stratix iv support section here:
    https://www.altera.com/products/fpga/stratix-series/stratix-iv/support.html
    Device pin outs
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/stratix4/ep4s100g2.pdf
    And no the Stratix board example project does not have a top file that shows the header assignments nor does it have an assignment file. A previous student was able to do the project that way, but didn't provide documentation of it so they want me to recreate it and document it.
    Do you have the Stratix board schematic? And does the Stratix board example project have a top file that shows the header assignments or an assignments file that does the same?
