14 years agoStratix III reconfigurable PLL switched clocks
Hello! I'm having some strange troubles with a reconfigurable PLL. I have to write my settings to c2 to configure c1 and vice versa. The baseclock is 5.25MHz. The M multiplier is 199 (100 ...
14 years agoHi Socrates,
How could this have an influence? And how can I check this? I would say that the input clock is not to slow, because I can get the desired frequencies (however on the wrong output). I've also kicked out the reconfig PLL and used a "non-reconfig" PLL. Everything worked just fine and I had no trouble with the frequencies (with the same input frequency; 5.25 MHz).
