17 years agoStratix III LVDS output delay in differential mode
I am using Altera's configurable output delay buffers and configured the differential mode. After that, ports_b were generated:
ENTITY iobuf_iobuf_out_phb1 IS PORT ( datain : IN STD_LOGIC_VECTOR (0 DOWNTO 0); dataout : OUT STD_LOGIC_VECTOR (0 DOWNTO 0); dataout_b : OUT STD_LOGIC_VECTOR (0 DOWNTO 0); io_config_clk : IN STD_LOGIC := '0'; io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '0'); io_config_datain : IN STD_LOGIC := '0'; io_config_update : IN STD_LOGIC := '0'; oe : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '1'); oe_b : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '1') ); END iobuf_iobuf_out_phb1; So far so good. Now, I am a bit confused how to assign them to the entity. Because when using differential pins, the n-Versions are typically generated automatically after switching the standard to LVDS in the assignment editor. I get something like that: OUTPUT(0) OUTPUT(1) ... OUTPUT(16) OUTPUT(0)(n) OUTPUT(1)(n) ... OUTPUT(16)(n) Of course I can place them in the pin planner - but how do I have to link these pins to the buffer in the port map?No RepliesBe the first to reply
