12 years agostratix iii FPGA-The AS prom configuration is not happening
i have a custom board with stratix iii FPGA. The AS prom configuration is not happening. After debug, it was found that nSTATUS pin impedance w.r.t Gnd is around 3 ohm. Config through JTAG is ok and ...
12 years agoI have to assume there is a build fault on your board. Do you have another board to compare it to, or is this the only one?
Unless nSTATUS is released, the AS configuration state machine is not going to start... Regards, Alex
