12 years agostratix iii FPGA-The AS prom configuration is not happening
i have a custom board with stratix iii FPGA. The AS prom configuration is not happening. After debug, it was found that nSTATUS pin impedance w.r.t Gnd is around 3 ohm. Config through JTAG is ok and ...
12 years agonstatus pins always stuck to 0 volts. Pullup resistor of 10k is connected to nstatus. 3 ohm is measured in board's off condition.
--- Quote Start --- What voltage do you see on nSTATUS once the FPGA is configured? Can I assume you have a pull-up resistor fitted to the pin? 3 ohms doesn't sound good. However, if you measured that with the board on but without the FPGA configured, that could make sense. Referring to: configuring stratix iii devices (http://www.altera.com/literature/hb/stx3/stx3_siii51011.pdf), figure 11-8 on page 11-18. Can you confirm this is how you've connected your FLASH device? Are your MSEL pins connected correctly? Regards, Alex --- Quote End ---
