17 years agoStratix III DPA lock behaviour
Hello, I've got some questions regarding the lock behaviour of Stratix III alt_lvds blocks (with internal PLL): 1. Simulation: Simulating these blocks shows that the DPA lock pin is asser...
17 years agoI didn't use Stratix III, about Stratix II and Arria DPA I know this: DPA can only work , if the input signal has edges. If this isn't guaranteed, the DPA operation should be halted. For an undriven LVDS input, the locked signal is meaningless, but not necessarily zero. I don't expect, that Stratix III is behaving basically different.
The Stratix III handbook tells: --- Quote Start --- The rx_dpa_locked signal only indicates an initial DPA lock condition to the optimum phase after power up or reset. You must not use the rx_dpa_locked signal to validate the integrity of the LVDS link. --- Quote End --- With a real input signal, I always experienced a considerable lock time. The handbook specifies an upper limit.
