14 years agostratix ii survive at high temperature 150?
Our device needs to survive in very harsh environment, the temperature might be 150 degree. Now I'm going to use military device, which support -55 to +125 degree. I would like to do timing analysis ...
14 years agoYou can use the timing advisor (Tools menu > Advisors > Timing Optimization Advisor) to check your project settings for options to change to have a better timing.
But those options are usually limited. If you still have problems after that then you will probably have to look at the VHDL code and try to make it more speed friendly (by adding pipeline stages for example). Here again the "Worst-Case Timing Paths" part of the Timequest report will help you find what you need to optimize.
