17 years agoStratix II GX Transceiver (basic) test design
Hi, I have a problem to get the Stratix II gx-Transceivers to run. My test-design uses a data-generator which produces a 32bit binary counter in a frequency of 100 MHz (from a PLL). I connected th...
17 years agohi DN2009, I was wondering; how did you manage to get your PLL to use the 155.52MHz signal? My design refuses to compile, saying that the voltage level is wrong. This is the error i get :
Pin P7 does not support I/O standard 3.3-V LVTTL Can you tell me why? Thanks. I have the exact same board as you.
