18 years agostratix II EP2S60
I am just starting with FPGA, and i need help if its possible. I have a board "stratix II EP2S60" and I want download the file "nios.sof" via Jtag Uart, but I have an error, I receive the messa...
18 years agoYou don't seem to have a valid Nios/IP Core license available. That means that Quartus creates a file called nios_time_limited.sof instead of nios.sof. When you download it and loose the connection to the device a timer starts to run and after about a specific time the Nios/IP Core will stop working.
You often loose connection to the device when downloading Nios software, so you get the message about non-tethered mode. The warning can be avoided by adding the file cpu_jtag_debug_module.vhd to your project file.
