16 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga.
I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resistor of low value around 100ohm. At the secondary coil (with has around 5x turns and bigger radius) I can get as high as 5 volts (AC - open circuit) when fpga1 outputs a high voltage. Perfectly as I need. Just when I try to connect coil2 as input to another fpga2, the voltage suddenly drops to 0.5volts! I have a feeling this has to do with impedance mismatching, eventhough I do not understand why since fpga2 is not outputting anything. Need to mention here that current arrives coil2 is very small (micros). But fpga2 needs only voltage to operate right? No need to care about current I guess! So what should I do to make sure coil2 sends at least 2volts to fpga2? I tried connecting a series resistor to coil2, did not work.
