17 years agoStratix II: Coil circuit
I am trying to create a very close range wireless communication using stratix II fpga. I want to achieve that using coil - coil communication. So I connected coil1 to fpga1 with a series resi...
17 years ago --- Quote Start --- A coil with a capacitive load (oscilloscope probe or a FPGA input) is a resonant circuit, connecting a different load changes the resonance frequency. It's basically possible to design a wideband inductive coupling, but most likely an amplifier with suitable frequency characteristic is required. You didn't tell about the waveform that's intended with your application. --- Quote End --- A great answer, and a confirmed one. I checked in the lab and what you said is absolutely true. As a start I want to send a digital clock signal. Now I have a problem. I am not sure how much capacitance the FPGA has, but if I only connect a coil of 100microH, I have Wo (the resonant frequency) at around 1.6MHz (which gives the maximum voltage to the FPGA input). I want to increase Wo alot, to a magnitude of 100s of MHz. I know I have two options to play with on the secondary circuit side: Either to make my L (coil inductance) lower, or make my C (capacitance) lower. At this point I have these questions: 1. What is the capacitance at the input of the FPGA (Stratix II GX)? I can connect a capacitor in series to make the capacitance much lower in this case. 2. If I made my L lower, the communication distance between primary and secondary circuits should be reduced as a result. And since I already have the coils almost touching each other, I do not think this is an option. What do you recommend? 3. Is there another better way to operate the circuit on a much higher frequency?
