STRATIX I AND EPC16
I am working on a board with STRATIX I device and a EPC16 as flash memory. I develop the FW in Quartus 13.1 because it is the lastest version supporting STRATIX I but i can not generate .POF for EPC16 as Quartus 13.1 does not support EPC16. To generate EPC16 .pof file i use Quartus 6.1 and the .sof file generated in Q13.1.
All works perfectly, but i wanted to know if there is any problem in generate EPC16 .pof files with Q6.1 and the .sof file that was generated in Quartus 13.1.
Thanks a lot.
Dani
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- NurAiman_M_Intel
.sof file generated in Q13.1 cannot be used in previous version. You will get error message when trying to put the .sof file in the programmer.
Aiman
- ddelafuente
Thank you Aiman for your answer.
I will try to clarify my question.
I need to convert .sof Q13.1 (stratix I) file into .pof Q6.1 file for EPC16 using convert programming files from Q6.1
Is there any issue i need to take into account to perform this convertion?
I usually do this convertion and i use .pof file (from Q6.1) into the EPC16 and works ok, but i need to know if under some condition this convertion could fail.
Thank you!
