16 years agoStratix 3 Kit, dynatron FAN. Heat dissipation.
Somebody has some documentation about the DYNATRON Fan use in the Stratix 3 development kit. When It is necessary to use? How to connect it? It is all that I can find: "The Dynatron SCP1 heat sink unit provides heat dissipation for the Arria GX device. The fan uses 190mA at 12 V and can dissipate 25 W of heat with no additional air flow in a lab-bench type environment. The 12 V is delivered through a two-pin 100-mil header". Thank you DABGNo RepliesBe the first to reply
