17 years agoSTRATIX 2 GX: CRU output frequency
Hi, I'm using the STRATIX 2 GX and the ALT2GXB. So I will transmit and receive the data with 6250 Mbps. I programm the Stratix 2 GX with Quartus 8.0. This are my configuration: Protoc...
17 years agoHello,
I have found the answer of my problem. The answer of the problem is, that only a Startix II GX with a speed grad of 3 can suport High speed transceivers up to 6.375Gbps. When you use an other speed grade the CRU recovers a clock, which is too fast for the PLD.
