LowLevelGuy
2 years agoStratix 10 settings -- what options are reversible?
When using the Quartus GUI to specify device settings, there are various options such as "HPS debug without certificate", "Disable JTAG", "Disable HPS debug", "Lock security fuses", etc... Do...
- 2 years ago
Only if you used OTP(One Time Programmable) security feature, the burnt fuse is not reversible. The others security features will be able to overwrite as long as you followed the procedure correctly.
regards,
Farabi
