8 years agoStrange PLL Clock causing me failing paths in cyc V design
Dear all, TimeQuest is warning me of a failing path in my Altera Cyclone V FPGA design. It says failing path with: Slack______From Node ____________________________________ ____to No...
8 years ago --- Quote Start --- Somewhere, you have another constraint targeting the port CLOCK_50_B5B based on the warning you got. Whatever that constraint is is part of what's messing things up. The failing path report is indicating that clk_100, your virtual clock, is the latch clock for the failing path, implying that the failing path is an output path. Is this correct? Is clk_100 driving whatever device you are feeding? Check your set_input_delay and set_output_delay constraints. Make sure that the correct virtual clock is referenced in them (upstream device virtual clock for set_input_delay; downstream virtual device clock for set_output_delay). Maybe just post your whole .sdc! That might make it easier to figure this out. --- Quote End --- Thank you, sstrell. Yes, clk_100 (stems from an PLL and source ref clk is CLOCK_50_B6B) is driving also the external hardware, which is connected via hsmc adapter. clk_100 is outputed at ALTDDIO_OUT. And yes, the failing_path is an output path. I already set the constraints for the output path, but only the output delay. This is recommended from the manufacturer of the external hardware interface connected to my desgin. I also have a working example from the manufacturer where failing path are not occuring. :confused: What confuses me is the use of the word port and pin in vhdl language. I see that the create_clock command uses get_ports at the end, bu in my understandin CLOCK_50_B5B is an input pin and not a port?! I'm also using ALTCLKCTRL IP Cores to promote the outputs of the PLL through the device. Here is the whole SDC-File.
create_clock -name CLK1 -period 20.0
create_clock -name CLK2 -period 20.0
create_clock -period 10 -name clk_100
derive_pll_clocks
derive_clock_uncertainty
set_output_delay -add_delay -rise -max -clock 6.000
set_false_path -from -to
set_multicycle_path -from {ram_ip_control:ram_ip_control_inst1|avl_address*} -to {ram_ip_control:ram_ip_control_inst1|avl_writedata*} -setup -end 6
set_multicycle_path -from {ram_ip_control:ram_ip_control_inst1|cal_data*} -to {ram_ip_control:ram_ip_control_inst1|avl_writedata*} -setup -end 6
set_multicycle_path -from {ram_ip_control:ram_ip_control_inst1|avl_address*} -to {ram_ip_control:ram_ip_control_inst1|avl_writedata*} -hold -end 6
set_multicycle_path -from {ram_ip_control:ram_ip_control_inst1|cal_data*} -to {ram_ip_control:ram_ip_control_inst1|avl_writedata*} -hold -end 6 Again, CLOCK_50_B5B is only driving PLL of hardmemory controller. This has an additional sdc file (fpga_lpddr2_p0.sdc), which is auto generated. Perhaps herein lies the problem of double constraining the same clk? But then one may wonder how this could create a failing path at the output? CLOCK_50_B5B is not driving the clk_100. Fitting the log says:
Info (332111): Found 27 clocks
Info (332111): Period Clock Name
Info (332111): ======== ============
Info (332111): 33.333 altera_reserved_tck
Info (332111): 20.000 CLK2
Info (332111): 10.000 clk_100
Info (332111): 20.000 CLOCK_50_B5B
Info (332111): 3.030 DDR2LP_CK_n
Info (332111): 3.030 DDR2LP_CK_p
Info (332111): 3.030 DDR2LP_DQS_n_OUT
Info (332111): 3.030 DDR2LP_DQS_p_IN
Info (332111): 3.030 DDR2LP_DQS_p_OUT
Info (332111): 3.333 pll_inst_100|pll_100_inst|altera_pll_i|general.gpll~FRACTIONAL_PLL|vcoph
Info (332111): 10.000 pll_inst_100|pll_100_inst|altera_pll_i|general.gpll~PLL_OUTPUT_COUNTER|divclk
Info (332111): 3.030 ram_inst1|fpga_lpddr2_inst|fpga_lpddr2_p0_sampling_clock
Info (332111): 3.030 ram_inst1|fpga_lpddr2_inst|pll0|pll_afi_clk
Info (332111): 6.060 ram_inst1|fpga_lpddr2_inst|pll0|pll_afi_half_clk
Info (332111): 15.151 ram_inst1|fpga_lpddr2_inst|pll0|pll_avl_clk
Info (332111): 15.151 ram_inst1|fpga_lpddr2_inst|pll0|pll_avl_phy_clk
Info (332111): 45.454 ram_inst1|fpga_lpddr2_inst|pll0|pll_config_clk
Info (332111): 3.030 ram_inst1|fpga_lpddr2_inst|pll0|pll_dq_write_clk
EDIT: Do I have to use create_generated_clock for clk_100 because clk_100 is not a clock which is coming into the fpga but is created via PLL from another clock? Could this be the problem and cause that timequest is reporting failing path? Thank you.
