10 years agoStrange max 10 startup & non-volatile operation
I have a PCB I made using the Max 10 10M16DAF256C8G dual supply series FPGA. I've observed some unexpected behaviors in terms of startup and non-volatile operation. When programming the board ...
10 years agoI've confirmed that this problem exists on 2 different boards now, where if power is removed and reapplied, the program doesn't start back up immediately. I also tried two different codes and they behave the same, so I'm thinking it's something in the hardware or programmer settings. Could using an $11 budget USB blaster be a culprit?
