10 years agoStrange Large IC delay in CycloneV
Hi, community, I am using 5CGTFD5C5F27C7 in my project to receive synchronous data from a 12-bit ADC. the data rate is 480Mbps, for i need to use dynamic io delay to compensate for the fixed del...
10 years ago --- Quote Start --- your waveform shows launch clock delay of 5.589 ns while latch clock delay is 3.391 + 1.339 (ns). This may give a clue to the negative setup slack. Why launch clock is so delayed? --- Quote End --- Yes, clock skew is around 0.86ns, this may be a source of the negative setup slack beside large data IC delay. I do not know why there is such a large skew between launch and latch clock, because it is out of my control. Both launch and latch clock come from the same 240MHz clock which is generated by a PLL. I checked the fitter result, this 240MHz clock is routed through global clock network, so there should not be such a large skew. The launch clock is fed into IOE to clock the two ddio input registers, while the latch clock is fed into LAB register, does that matter? does routing to IOE be a difficult task? i have no idea. Best Wishes, ingdxdy
