9 years agoStrange behavior with On-chip Mem
In my simulations, some memory reads are next cycle, some are in two cycles, which is causing problems. Shouldn't it always be a consistent single-cycle with on-chip mem? I've attached a screen shot....
9 years agosstrell,
The slave component is a generic On-Chip Memory RAM: 2-Port, exported from the Quartus IP Catalog. With two read/write ports, Q_a output as 64-bit words, Depth is 512 words, Auto memory type, Single Input clock, No byte enable or read enable, Registered read output ports q_a and q_b Asynchronous clear supported, Don't care on mixed port read during write, Same port read during write is new data, Initialize to blank. As you can see all the settings are normal. The read is one cycle before incrementing the state. Would it be a problem ifthe source address is registered? After State_1, the address is derived from a register. Still I don't see why there's a two cycle delay. On the Avalon-MM Master, the following is given. It seems to be the address port that is causing the problem: registers wires The actual verilog code: assign avm_srt1_address = f_find_op_inb ? node_pnt_inb * 10 + node_offset_inb : avs_s1_address[4 +:9 ] * 10+ avs_s1_address[3:0]; assign avm_srt1_read = f_find_op_inb ? 1'b1 : avs_s1_read; // seems to have no affect on the delay assign avm_srt1_write = f_find_op_inb ? 1'b0 : avs_s1_write; // seems to have no affect on the delay assign avm_srt1_writedata = avs_s1_writedata[63:0]; // seems to have no affect on the delay assign node_pnt_inb = {row_pnt_inb, column_pnt_inb[5:0]}; assign column_pnt_inb = check_hit[5:0]; check_hit = (!skip_array[ 0 ] & (target == search_string[ 0 ])) ? {1'b1, 8'd 0 } : (!skip_array[ 1 ] & (target == search_string[ 1 ])) ? {1'b1, 8'd 1 } : (!skip_array[ 2 ] & (target == search_string[ 2 ])) ? {1'b1, 8'd 2 } : (!skip_array[ 3 ] & (target == search_string[ 3 ])) ? {1'b1, 8'd 3 } : (!skip_array[ 4 ] & (target == search_string[ 4 ])) ? {1'b1, 8'd 4 } : (!skip_array[ 5 ] & (target == search_string[ 5 ])) ? {1'b1, 8'd 5 } : 9'b0; ... always @ (posedge csi_clock_clk or posedge csi_clock_reset) begin if(csi_clock_reset) begin ... end else begin case (state) ...... STATE_INB_IDLE: begin node_offset_inb <= '{default:0}; row_pnt_inb <= '{default:0}; ...... STATE_READ_NEXT: begin node_offset_inb <= node_offset_inb +1; row_pnt_inb <= row_pnt_inb +1;
