14 years agoStrange Behavior when using case statement on EPM3128A
I have been having a problem with a project that I am doing and have asked many people in the office to no eval. I am using an Altera EPM3128A Device with a GCLK1 speed of 24MHz, I then devide ...
14 years agoThis does not help.
You have to define separate register signals for your LED's and give these signals a default value.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY USBDownloader IS
GENERIC (
CLK_DIVIDER_6 : integer := 20000000 --------DO NOT CHANGE--------
PORT (
----------------------CLOCKS--------------------------------------
SYS_CLK_IN : IN std_logic;
CLK_6MHz : OUT std_logic;
ULED : OUT std_logic;
RLED : OUT std_logic
END ENTITY USBDownloader;
ARCHITECTURE rtl OF USBDownloader IS
TYPE case_counter_type IS (a, b, c);
-- Declare Constants and Variables
SIGNAL CLK_TEMP_6 : std_logic := '0';
SIGNAL CNT_6 : integer RANGE 0 TO 20000000 := 0;
SIGNAL case_counter : case_counter_type := a;
SIGNAL uled_r : std_logic := '1';
SIGNAL rled_r : std_logic := '1';
BEGIN
PROCESS (CLK_TEMP_6)
BEGIN
IF rising_edge (CLK_TEMP_6) THEN
CASE case_counter IS
WHEN a =>
uled_r <= '0'; ----GREEN LED ON-----
reld_r <= '1';
case_counter <= b;
WHEN b =>
uled_r <= '1';
rled_r <= '0'; -------RED LED ON-----
case_counter <= a;
WHEN OTHERS =>
NULL;
END CASE;
END IF;
END PROCESS;
PROCESS (SYS_CLK_IN)
BEGIN
IF (SYS_CLK_IN'EVENT AND SYS_CLK_IN = '1') THEN
CNT_6 <= CNT_6 + 1;
IF (CNT_6 = CLK_DIVIDER_6-1) THEN
CLK_TEMP_6 <= NOT CLK_TEMP_6;
CNT_6 <= 0;
END IF;
END IF;
END PROCESS;
CLK_6MHz <= CLK_TEMP_6;
ULED <= uled_r;
RLED <= rled_r;
END rtl;
