Stock Availability or Replacement Part EPM7160STI100-10
- 2 years ago
Ah, thank you for supplying the PDN1619 & PDN1709 documents, however, as stated in original inquiry status of obsolescence was already known.
Redesign is not an option at this point, but appreciate the recommendation for potential part family's to look at.
You might investigate the Microchip/Atmel ATF150n series parts.
They are in production and are functional equivalents to the Intel/Altera EPM7000S and EPM3000A series parts.
There are translation tools to convert .pof image files to .jed image files for the device.
I have personally done this for EPM7064S to ATF1504AS, and EPM7128S to ATF1508S, both in PLCC packages.
I don't believe there is an equivalent part to the EPM7160S, however, so there is not an exact drop in solution.
As I said earlier Intel does not currently have ANY equivalent to the 5V EPM7nnnS series parts. They are out of production.
Rochester Electronics does stock a lot of obsolete parts, including Altera CPLDs.
See: https://www.rocelec.com/search?q=EPM7
However they have little stock in the EPM7160S variation.
