BitBrain
3 years agoState Machine Controller for SOC FPGA/PLD
Long ago, I met an engineer that stated they had the license from Intel to modify the microcode. Using this, would it be possible to use Intel microcode for a RISC processor, to run / control the des...
mabdrahi
Contributor
3 years agoHi Bitbrain,
Since we dont have any update from you, , I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 4 out of 5, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Thank you,
Aliff
