16 years ago
SSS stabillity issues
This is killing me... I had a design just under way using SSS and lost the disk on my laptop. I actually had SSS running and modified it to parse commands so I know it works... When I load/build the verilog source for nios2_linux_3c120_125mhz_sys and generate a SSS with BSP on 9.1 sp1 I get the following:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Could not locate flash sector with MAC address.
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x08004000
WARNING : Unknown PHY found at PHY address 0x12 of MAC Group[0]
WARNING : Please add PHY information to PHY profile
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
WARNING : PHY[0.0] - PHY not found in PHY profile
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 169.254.120.10
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
The PC is at 169.254.120.99 with a mask of 255.255.0.0
No ping, no telnet - any thoughts? It's likely I'm missing something dumb...
Thanks - C
1 Reply
    Just a few thoughts:
    - try with DHCP disabled
    - check if the activity led (I suppose your board has one) flashes when you ping the board
    - usually I have the SSS task created message and then the SSS listening: maybe the message order it's only a matter of tasks priorities, however I'd check this point.
    Cris
