17 years agoSRAM switch and M4K
I read that FPGAs are either anti-fuse or SRAM switch and Cyclone II is a SRAM type FPGA. Also, I found the Cyclone II has M4K RAM memory. I am wondering if M4K RAM and the SRAM switch are the sam...
17 years ago --- Quote Start --- Thanks for the reply. I am wondering if we can also manually change values in SRAM switches. Also, my another curiosity is: since SRAM stores both switch as well as logic element configuration, is it possible to which is which in .sof file? --- Quote End --- Hi, I assume that you would like to do some fast design cahnges without running a complete P&R run ???? For the purpose you can use the Quartus "Chip Editor". Kind regards GPK
