14 years agoSRAM Read Question
Am using TerASIC DE2-115. SRAM is asynchornous 10ns ISSI. Have Nios CPU and custom interface (TDR) multiplexed to SRAM. CPU interface works perfectly. However, when I try to read SRAM from TDR interface, the readdata component always reports the previous address's data, not the current. Clock is 100Mhz and I currently have 3 wait states set between activating the read and reading the data. Have also tried setting WS to 10. Results are different, but still incorrect. It seems that once the control and address lines are set, and after 10ns, the readdata should become, and remain, valid until I dectivate the control lines.
Below is SRAM interface and the TDR interface controlling it. I've excluded some of the control logi (cpu_tdr_sel, etc.) Would appreciate any thoughts on my mistake. It seems that since I am at 100Mhz 3 WS would be more than sufficient. Also, from the ISSI datasheet, it appears that I should be able to set all control (WE,OE,CS,UBE,LBE) and address lines at the same time. Apologies for lengh post... RT /********* SRAM Interface *************/ reg [15:0] s_writedata_reg; reg [15:0] tdr_writedata_reg; assign SRAM_DQ = ((cpu_tdr_select == cpu_sel) ? (~SRAM_WE_n ? s_writedata_reg : 16'hzzzz) : (~SRAM_WE_n ? tdr_writedata_reg : 16'hzzzz)); always @(posedge clk) begin if (reset_n == 0) begin s_readdata = 16'h0000; s_writedata_reg = 16'h0000; SRAM_ADDR = 20'h00000; SRAM_LB_n = 1'b1; SRAM_UB_n = 1'b1; SRAM_CE_n = 1'b1; SRAM_OE_n = 1'b1; SRAM_WE_n = 1'b1; end else begin if (cpu_tdr_select == cpu_sel) // CPU begin s_readdata = SRAM_DQ; s_writedata_reg = s_writedata; SRAM_ADDR = s_address; SRAM_LB_n = s_byteenable_n[0] | s_chipselect_n; SRAM_UB_n = s_byteenable_n[1] | s_chipselect_n; SRAM_CE_n = s_chipselect_n; SRAM_OE_n = s_read_n | s_chipselect_n; SRAM_WE_n = s_write_n | s_chipselect_n; end else // TDR begin tdr_readdata = SRAM_DQ; tdr_writedata_reg = tdr_writedata; SRAM_ADDR = tdr_address; SRAM_LB_n = tdr_byteenable_n[0] | tdr_chipselect_n; SRAM_UB_n = tdr_byteenable_n[1] | tdr_chipselect_n; SRAM_CE_n = tdr_chipselect_n; SRAM_OE_n = tdr_read_n | tdr_chipselect_n; SRAM_WE_n = tdr_write_n | tdr_chipselect_n; end end /********** TDR Host *************/ reg perform_sram_test; reg [3:0] sram_test_state; localparam waiting_to_start_sram_test = 0; localparam start_sram_test = 1; localparam sram_wait = 2; localparam sram_end_read = 3; reg [7:0] sram_wait_state_counter; reg [31:0] sram_checksum; reg [19:0]local_sram_address; task enable_sram_read; input [31:0] sram_index; begin sram_chipselect_n = 0; sram_write_n = 1; sram_address = sram_index; sram_read_n = 0; sram_byteenable_n[0] = 0; sram_byteenable_n[1] = 0; end endtask task disable_sram_read; begin sram_chipselect_n = 1; sram_write_n = 1; sram_address = 20'hzzzzz; sram_read_n = 1; sram_byteenable_n[0] = 1; sram_byteenable_n[1] = 1; end endtask // Manage SRAM verification always @(posedge clk or negedge reset_n) begin if (reset_n == 0) begin perform_sram_test <= 1; sram_test_state <= waiting_to_start_sram_test; sram_wait_states <= 3; end else if (clk_en) begin if (chipselect && ~write_n && (address == 6)) begin perform_sram_test <= 0; end if (chipselect && ~write_n && (address == 8)) begin sram_wait_states <= readdata; end case (sram_test_state) waiting_to_start_sram_test: begin if (perform_sram_test == 0) begin local_sram_address = 0; sram_wait_state_counter = sram_wait_states; sram_checksum = 0; perform_sram_test <= 1; sram_test_state <= start_sram_test; end end start_sram_test: begin enable_sram_read(local_sram_address); sram_test_state <= sram_wait; end sram_wait: begin sram_wait_state_counter = sram_wait_state_counter - 1; if (sram_wait_state_counter == 0) begin sram_checksum = sram_checksum + sram_readdata; sram_test_state <= sram_end_read; if (sram_readdata != 0) begin int_sram_address = local_sram_address; int_sram_data = sram_readdata; end end end sram_end_read: begin disable_sram_read(); local_sram_address = local_sram_address + 1; if (local_sram_address <= 20'h3ffff) begin sram_wait_state_counter = sram_wait_states; sram_test_state <= start_sram_test; end else begin sram_test_state <= waiting_to_start_sram_test; fire_int <= ~fire_int; end end default: begin disable_sram_read(); sram_test_state <= waiting_to_start_sram_test; end endcaseNo RepliesBe the first to reply
