10 years agoSRAM Controller on DE2-115 Cyclone IV E
I'm planning to use the SRAM to store a 640 x 480 image from the tv decoder output capture.. But I can't find any sample project that uses the SRAM Controller.v in order for me to perform sequential ...
10 years agoNo, you certainly don't have to use Nios to put the SRAM to use. You can write your own interface to do so.
--- Quote Start --- But I can't find any sample project that uses the SRAM Controller.v --- Quote End --- SRAM doesn't need a 'controller' in the same way the SDRAM does. Present an address & data and strobe the data in (using WE & CE). Alternatively, present an address and activate CE & OE to get the data out. This memory interface tutorial (https://www.google.nl/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahukewjlg9_4ln7kahwdtbqkhv1ibwiqfggfmaa&url=http%3a%2f%2fece.wpi.edu%2f~rjduck%2fverilog%2520memory%2520module%25207.pdf&usg=afqjcneszzvqt4gxd-6cu6wglui8groflw&bvm=bv.113370389,d.d24) discusses accessing SRAM and has some useful timing diagrams along with an SRAM verilog model. The 'Simplified Read/Write Operation' figures (pages 14/15), along with the waveform simulation on the last page should, I hope, clarify what signals you need to generate as part of your interface. Cheers, Alex
