17 years ago
SRAM Connection problems in NiosII(Cyclone III)
Hi all,
I am working on a project to port NiosII softcore processor, SRAM connected via a tristate bridge and a custom MAC into Cyclone III(EP3C25F324C8). I used Altera's SOPC builder to have it working but the problem i faced was in the pin assignment where ALTERA assigns its internal signals to the pins dedicated to SRAM's pins and i am not able to assign two of my SRAM's data pins.
I see this error on compilation.
Error: Can't place multiple pins assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
Info: Pin data_to_and_from_the_sram_0[1] is assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
Info: Pin ~ALTERA_ASDO_DATA1~ is assigned to pin location Pin_D1 (IOPAD_X0_Y27_N7)
but my datasheet holds the pin D1 for sram_dq1.
Can anyone help me out in this issue.
Many Thanks to all,
Jude.
    It worked!!!... Thank You so much...I would be very happy if u can also help me in solving this issue...
    After generation of the code built in SOPC and programming the device with the sof file, when i go into Nios IDE to run a hello world program it says "The Software settings associated with this project is damaged".
    Can u help me out in this issue..
    Many thanks...
    Go to the Assignments menu, click on Device.
    Then click on the "Device and pin Options" button, go to the "Dual-Purpose Pins" tab, select "Data[1]/ASDO" and change the value to "Use as a regular I/O".
    Thank u so much... But can u just let me know what all modifications should i make in the device settings...
    You need to change the device settings in Quartus, to be able to use the DATA1 programming pin as a regular I/O after configuration.
