13 years agospecifications of external clock signal DE2 Board and Starter Development Board
Hi, im trying to synchronize a comunication system with a 10MHz clock, for that, I'm using a PLL IC (MM74HC4046), then the main issue is that this IC gives 5 Volts signal, and after research of my bo...
13 years agoLook at the schematic for the DE2. I just looked at an old printed copy and the external clock SMA connector is followed by a 1k pull-down and then goes directly to an FPGA pin.
If you have the clock source close to the board, then you could put a 1k series resistor between the clock source and the DE2 board. That external 1k and the on-board 1k would create a voltage divider, resulting in a clock signal with a peak of about 2.5V on the FPGA pin - this assumes that you do not have much ringing though - so check with an oscilloscope. If you look in the handbook you will find there is a specification for ringing/overshoot. So long as you're under the handbook values, you will not damage the FPGA clock input pin. Cheers, Dave
