12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agohere is my attempt as guide only:
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity bubblesort is
port(
clk : in std_logic;
we : in std_logic := '1';
trigraph : in std_logic_vector(7 downto 0) := x"0F";
duration : in integer range 0 to 1023 := 5;
dout : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of bubblesort is
signal ram_din, ram_dout : std_logic_vector(8 downto 0) := (others => '0');
type mem is array(0 to 1023) of std_logic_vector(8 downto 0);
signal ram : mem := ((others=> (others=>'0')));
begin
--infer ram
process(clk)
begin
if(rising_edge(clk)) then
ram_dout <= ram(duration);
if(we = '1') then
ram(duration) <= ram_din;
end if;
end if;
end process;
ram_din <= trigraph & we;
dout <= ram_dout(8 downto 1);
end rtl ;
notice I use we as flag that a write occurred in case data is zeros all. after all ram write is done you need to control address (instead of duration) so that you read from address 1023 to 0 to get the code out provided bit(0) of ram_dout is '1'. I am assuming each code will have its unique duration
