16 years agosopc builder
hello all.. please someone explain to me:confused: ...when i run flash program in NIOS II, it happened to write this in console: # !/bin/sh# # This file was automatically generated by the N...
16 years agoHave a look at the messages you get :
--- Quote Start --- There are no Nios II processors available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. --- Quote End --- it could be that the fpga has no nios configuration during your try to access the flash via command line, in fact the fpga could be empty or has a design without a nios core inside or ... --- Quote Start --- # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 --sidp=0x034410d8 --id=761933568 --timestamp=1268280966 "ext_flash.flash" --- Quote End --- as you use the -timestamp option, the fpga has a different image inside than the one you specified for the first possible cause. load the expected fpga image and the try again to programm the flash, for the second cause, update the fpga image or the timestamp value or remoce the timestamp option.
