16 years agoSome issues about functional simulation
Hi,all when i do the functional simulation for my projection,i find that some of the initial values of my signals are not cleared to "0".how can i do to clear them? thanks.
16 years agoi still don't catch it.
it is a example of a polyphase filter.when i simulate using q ii,simply functional simulation,the signals are not reset to '0'. PACKAGE n_bits_int IS SUBTYPE BITS8 IS INTEGER RANGE -128 TO 127; SUBTYPE BITS9 IS INTEGER RANGE -2**8 TO 2**8 - 1; SUBTYPE BITS17 IS INTEGER RANGE -2**16 TO 2**16 - 1; TYPE ARRAY_BITS17_4 IS ARRAY (0 TO 3) of BITS17; END n_bits_int; LIBRARY work; USE work.n_bits_int.ALL; LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_arith.ALL; USE ieee.std_logic_signed.ALL; ENTITY db4poly IS PORT (clk : IN STD_LOGIC; x_in : IN BITS8; y_out : OUT BITS9); END db4poly; ARCHITECTURE flex OF db4poly IS TYPE STATE_TYPE IS(even,odd); SIGNAL state : STATE_TYPE; SIGNAL x_odd,x_even,x_wait : BITS8; SIGNAL clk_div2 : STD_LOGIC; SIGNAL r : ARRAY_BITS17_4; --Arrays for multiplier and trap; SIGNAL x33,x99,x107,y : BITS17; BEGIN Mutiplex:PROCESS --->Split into even and odd BEGIN --samples at clk rate WAIT UNTIL clk ='1'; CASE state IS WHEN even => x_even <= x_in; x_odd <= x_wait; clk_div2 <= '1'; state <= odd; WHEN odd => x_wait <= x_in; clk_div2 <= '0'; state <= even; END CASE; END PROCESS Mutiplex; AddPolyphase:PROCESS(clk_div2,x_odd,x_even,x33,x99,x107) VARIABLE m : ARRAY_BITS17_4; BEGIN --compute auxiliary multiplication of the filter x33 <= x_odd * 32 + x_odd; x99 <= x33 *2 + x33; x107 <= x99 + 8 * x_odd; --compute all coefficients for the transposed filter m(0) := 4 * 32 * x_even - x_even; m(1) := 2 * x107; m(2) := 8 * (8 * x_even - x_even) + x_even; m(3) := x33; ----> compute the filters and infer registers IF clk_div2'EVENT and (clk_div2 = '0') THEN --compute filter G0 r(0) <= r(2) + m(0); r(2) <= m(2); --compute filter G1 r(1) <= -r(3) + m(1); r(3) <= m(3); --add the polyphase components y <= r(0) + r(1); END IF; END PROCESS Addpolyphase; y_out <= y / 256; --connect to output END flex;
