10 years agoSome basic questions about DDR
Hi all, I am studying the RTL based example code of LPDDR2 demonstration of Cyclone V 5CGXFC5C6 development kit from Terasic. Basically, this demo code utilizes a LPDDR2 IP, and then w...
10 years agoI just found that if I de-select the "Enable Hard External Memory Interface" in figure "IP Setting_1", then the data width of avl_rdata and avl_wdata will comply with the rule: Full rate -- x2; Half rate -- x4.
If I select this feature, then I can only select "Full rate", and data bus would be 32, the same with DQ width of memory chip. So, what is going on here?
