Solution: USB Blaster Driver for Windows 11 ARM
- 3 years ago
The USB Blaster driver attached to my original post should work for Quartus 19.1 through 23.3 on Windows 11 ARM.
I've attached proven drivers for Quartus 17 through 18, Quartus 13, and Quartus 9. To install a driver without disabling signature enforcement, first add the security certificate to (Local Machine) Trusted Root Certification Authorities as well as (Local Machine) Trusted Publishers.
If you have a version of Quartus not listed, the ARM driver version with DLL file sizes matching those found in \quartus\drivers\usb-blaster\x64\ should work. If there is no match, replacing the DLL files of any ARM driver version and disabling driver signature enforcement should work.
Thank you, I was able to install the driver, but the Quartus does not see the USB Blaster. How to solve this problem?
You need to select it in Hardware Setup…
If it still doesn’t show up, then double check in Device Manager that the USB Blaster is detected and not missing a driver.
I can only confirm that it worked with a de10-nano by following the steps in the guide to test their first FPGA example.
