SoC and i2c read/write transaction without stop in between.
I connect FXOS8700CQ to SoC with Intel FPGA Avalon I2C (Master) Core.
Add to *.dts:
i2c_accelerometer: i2c@0x000010300 {
compatible = "altr,softip-i2c-v1.0";
reg = <0x00000000 0x00010300 0x00000040>;
interrupt-parent = <&hps_0_arm_gic_0>;
interrupts = <0 51 4>;
clocks = <&clk_0>;
clock-frequency = <100000>;
#address-cells = <1>;
#size-cells = <0>;
fifo-size = <32>;
}; //end i2c@0x000010300 (i2c_accelerometer)Program:
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <linux/i2c.h>
#include <linux/i2c-dev.h>
#include <unistd.h>
#define I2C_ADAPTER "/dev/i2c-0"
void read_buffer(int fd, unsigned short addr)
struct i2c_rdwr_ioctl_data data;
struct i2c_msg messages[2];
unsigned char write_buf[1] = {0x0D}, read_buf[1] = {0x00};
* .addr - Адрес устройства (датчика)
* .flags - операция чтения или записи (0 - w, 1 - r)
* .len - кол-во передаваемых/принимаемых сообщений
* .buf - буфер на чтение или запись
messages[0].addr = addr;
messages[0].flags = 0;
messages[0].len = 1;
messages[0].buf = write_buf;
messages[1].addr = addr;
messages[1].flags = 0x1;
messages[1].len = 1;
messages[1].buf = read_buf;
data.msgs = messages;
data.nmsgs = 2;
ioctl(fd, I2C_TIMEOUT, 2); // set the timeout
ioctl(fd, I2C_RETRIES, 4); // set the retries
if (ioctl(fd, I2C_RDWR, &data) < 0)
printf("Cant send data!\n");
else
printf("ID = 0x%x\n", read_buf[0]);
int main(int argc, char **argv)
int fd;
* Open I2C file descriptor.
fd = open(I2C_ADAPTER, O_RDWR);
if (fd < 0) {
printf("Unable to open i2c file\n");
return 0;
while(1)
read_buffer(fd, 0x1E);
sleep(1);
return 0;
}I expect to see on i2c bus:
ST-ADDRESS-W-ACK-DATA-ACK-ST-ADDRESS-R-ACK-DATA-ACK-SP
But in reality, I see:
ST-ADDRESS-W-ACK-DATA-ACK-SP-ST-ADDRESS-R-ACK-DATA-ACK-SP
For this reason, reading does not work.
How I can set read/write transaction without stop in between?
- MCher6
Hi, KTan9.
Yes, a modified driver file has been attached to the previous message. Unfortunately, I am not an expert in creating drivers and my fixes are probably not optimal and need to be corrected. I wrote to the driver author (Thor Thayer from Intel), but I haven’t received a response yet.
Let me know any news on this issue.
- KennyT_altera
Do you mind to share with us which coding that you have make the changes for the driver to be working?
- MCher6
I managed!
The changes are very rough and not entirely correct, but the driver works. I did not completely check, but maybe someone will fall into a similar situation.
- MCher6
Probably a problem in Linux driver i2c-altera.c
According to the documentation (Documentation/i2c/dev-interface):
ioctl (file, I2C_RDWR, struct i2c_rdwr_ioctl_data * msgset)
Do combined read / write transaction without stop in between.
Only valid if the adapter has I2C_FUNC_I2C. The argument is
a pointer to a
struct i2c_rdwr_ioctl_data {
struct i2c_msg * msgs; / * ptr to array of simple messages * /
int nmsgs; / * number of messages to exchange * /
The msgs [] themselves contain further pointers into data buffers.
If you’re looking at what I2C_M_RD I’m flag on
Overlaying the ivectl's
The i2c-altera.c driver has I2C_FUNC_I2C:
static u32 altr_i2c_func (struct i2c_adapter * adap) { return I2C_FUNC_I2C | I2C_FUNC_SMBUS_EMUL; }The driver sets STOP when i2c_msg.len = 1 (last data byte):
static void altr_i2c_transfer (struct altr_i2c_dev * idev, u32 data) { / * On the last byte, send STOP * / if (idev-> msg_len == 1) data | = ALTR_I2C_TFR_CMD_STO; if (idev-> msg_len> 0) writel (data, idev-> base + ALTR_I2C_TFR_CMD); }Correctly put STOP after the last byte of the last message.
Any thoughts on how to fix this?
