13 years agosmart parking
i need to design a car park indicator system for a space with 8 lots.
With two gates each entrance to the parking lot And one exit from the parking lot. Hardware works on the principle of LDR Once the LDR is covered changes something. it needs to have the following specifications: a seven-segment display to indicate the number of free lots. presettable up/down counter Counter displays the entry and out of cars each lor has a light which will turn on to indicate that is free the light should turn off when the lost is occupied when the lot is filled to the maximun of 8 cars, the seven-segment should display 'F' the indicate it is full. Once car comes the front gate and LDR covers the gate opens Once he passed the gate and covers the second LDR gate closes The same principle also exit. I need it urgently Thanks u3 Replies
Give it a try, than ask if you have problems.
This thread is almost identical to:http://www.alteraforum.com/forum/showthread.php?t=42110. So I see you really need it urgently. I can give you one hint: make "lego"blocks. So a part for the 7-seg, LDR, etc. - Altera_Forum
I need code
At least a something that I can to work with him * Or any link code that can be related I need it urgently Thank you - Altera_Forum
Search the web. There are enough examples there, and there are a few good books about this too.
see:http://www.alteraforum.com/forum/showthread.php?t=41998&highlight=vhdl+book
