10 years agoSmallest configuration memory for Cyclon V SE SoC
Hi, I am currently designing a product(well, not me, I am just a student in an internship that was put on a project), and one of our option is to use a Cyclon V SE so we get an ARM cortex running lin...
10 years agoThe Cyclone V SoC chips are configured by default from the same SD card or serial flash that holds the Linux kernel and file system image. There is no need for a separate configuration chip unless you want it to boot a few seconds faster. If you do decide to use a separate configuration chip, you will need the bigger one. Note that some (but not all) non Altera serial flash chips can also be used to hold Cyclone V configuration images.
