14 years agoSlow UDP receiving with inichestack
Hi, everyone. I got a problem here with my udp packet receiving. I use TSE as the MAC driver and inichestack TCP/IP, running on the Altera Cyclone 3 C120, I noticed that there is a signifi...
14 years agoHello there,
Thanking you for your prompt response, OK I have found there are redefinitions about NUMBIGBUFS and NUMLILBUFS in pk_alloc.c (Line No. 55 and 57), as you says get rid of them mean I should comment both of them in pk_alloc.c and Second one “in pk_init the buffer initial size is exact the size that ipport.h defined”, in ipport.h there is no keyword like pk_init. So little confuse …. I have attached my ipport.h and pkalloc.c for your reference please point out where should I edit. Regards kaushal
