15 years agoSimulink to FPGA implementation
Hi, there is a way by which you can interface FPGA with your simulink so that you can put your input in to the block and the input get processed by the FPGA and oupput result is shown on the Si...
15 years agoHi
I think you can do that (HIL-Tests) with altera dsp builder for Matlab/Simulink. But probably it is a bit oversized if you don't want to generate VHDL out of your simulink model. It's quite expensive if you don't want to use all features of it. Regards
