admaris
1 year agosimulation for the HBM2E Interface FPGA IP
I am performing a simulation for the HBM2E Interface FPGA IP using Intel FPGA Edition 2024.1 with device model AGMF039R47A1E2VR0. Following the steps from the High Bandwidth Memory (HBM2E) Interface ...
admaris
1 year agoHi
Thank you for your reply.
The kernel is as follows:
Linux legion-desktop 5.15.0-122-generic #132~20.04.1-Ubuntu SMP Fri Aug 30 15:50:07 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
I tried to launch Questasim with the command "vsim -nocvg &" and changed the setup script, which is the same as what you used.
The EMIF IP example design is directly retrieved from the IP library.
I printed the output of running HBM2e into the info.log file below. Thank you~
