admaris
2 years agosimulation for the HBM2E Interface FPGA IP
I am performing a simulation for the HBM2E Interface FPGA IP using Intel FPGA Edition 2024.1 with device model AGMF039R47A1E2VR0. Following the steps from the High Bandwidth Memory (HBM2E) Interface ...
AdzimZM_Altera
1 year agoHi
I cannot replicate the issue from my end.
Here the setup that I used:
- I'm using Quartus Prime version 24.2.0 build 40
- The Questa sim version 2024.1
- I'm lunching Questasim through terminal with command "vsim -nocvg &"
- In msim_setup.tcl, I've changed the last two lines of the script from
- ld to ld_debug
- add wave -position end sim:/ed_sim/*
- run -all
Are you using a Windows OS or Linux?
Can you test on different machine?
Can you also test on different simulator?
Adzim
