admaris
2 years agosimulation for the HBM2E Interface FPGA IP
I am performing a simulation for the HBM2E Interface FPGA IP using Intel FPGA Edition 2024.1 with device model AGMF039R47A1E2VR0. Following the steps from the High Bandwidth Memory (HBM2E) Interface ...
AdzimZM_Altera
1 year agoHi
Can you provide the HBM2E IP parameter that you used?
I will try to replicate the issue at my end.
The Quartus version that you used is 24.1, correct? and Questasim version is 2024.1, correct?
Have you tried with different simulator?
Adzim
- admaris1 year ago
Hi
I am using the default parameters for the HBM2E IP and haven't changed any settings. The parameter interface is as follows.
The Quartus version and Questasim version are 2024.1. Thank you.
