19 years agoSimulating the Parallel Flash Loader
Is it possible to simulate the PFL(Parallel Flash Loader)?
19 years agoIf you want to simulate the configuration part of the PFL, this is possible. Create a Vector Waveform File in the Quartus II software, specify the correct input vectors and then use the Quartus II simulator to simulate the configuration. You need to understand what are the correct input vectors that will allow configuration to happen, eg the Conf_done signal must be low, nStatus must be high etc.
