11 years agoSimulating a QSYS system featuring a HPS
Hello, I'm developing a QSYS system to transmit data via LVDS. Within this module there are the common blocks of a qsys system with a processor, namely memory, jtag, HPS, parallel IOs etc. Ther...
11 years ago --- Quote Start --- What am I doing wrong? --- Quote End --- Its hard to tell, since you did not provide the error messages. Have you tried simulating a Qsys system before? Do you know what the Avalon-MM Master BFM is? If not, start off simple, read through this tutorial ... http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial I'd recommend starting with the tutorial example, and then start adding the components you want to test. The HPS component probably requires the AXI BFM master. This BFM requires either a subscription edition of Quartus or the purchase of a $500 license. Trust me, just go with the Avalon-MM BFM :) Cheers, Dave
