18 years agoSimulate SDRAM
Hi, I wish to test my design which uses 1. multipliers 2. DDR2 controller 3. SDRAM I will be reading data inputs from the SDRAM, multiplying it, and storing it back into the SDRAM. ...
18 years agoIf you know which SDRAM you are going to use, you can obtain Verilog/VHDL simulation models of that chip from the manufacturer. I ahve used models for Cypress chips in the past. Have a look at this link: http://www.eda.org/rassp/vhdl/models/memory.html
Regards, Kumar Vijay Mishra.
